wired_retired
  • 6
Can I programme Virgin remote to turn on my LG TV?
I was able to turn on/off my LG TV with my Sky remote.
Is it possible to do the same with my Virgin Media remote?
jb66
  • 12.14K
  • 899
  • 1.75K
Re: Can I programme Virgin remote to turn on my LG TV?
Yes you can do this with the virgin remote, have you already tuned it in to do the volume?
HowardML
  • 12.24K
  • 1.42K
  • 5.72K
And here's how:
https://www.virginmedia.com/help/virgin-tv-using-tv-remote
wired_retired
  • 6
Hi, yes the tech set up volume control but not the ability to turn the TV off.
Can you explain how?
Ernie_C
  • 18.39K
  • 2.01K
  • 4.49K
If the volume is working, try the long press of the standby button. It should flash green, rather than red, and toggle your TV off or on.
If this isn’t working, you need to try more codes to see if any work.
wired_retired
  • 6
Thank you for that.
