TajMahal
Message 1 of 5
C130 and V210 cable errors
Hello
I have a C130 error code and on demand and catch up temporarily unavailable (V210)
the tivo box doesn't have a network cable, never has been ok for over 5 years I think.
both these errors have appeared in the last week. Also got a green flashing light on the front.
tried a reset of the box from the menus a couple of times.  Checked the coaxial cables and all okay. The picture is occasionally pixelated on several channels.
Can't run a test from the web, that just gives the oops something's wrong screen..
please can someone from Virgin take a look and advise next steps please. Account details are all up to date.
  • 6.45K
  • 1.01K
  • 1.59K
Message 2 of 5
Re: C130 and V210 cable errors
Hi TajMahal,
You should follow the advice from @japitts in this thread TiVo-service/On-demand-not-working
Dave
Have I helped? Click to mark as a Helpful Answer or use Kudos to say thanks
japitts
  • 12K
  • 1.66K
  • 2.56K
Message 3 of 5
The green flashing light is a classic symptom of an old TiVo box having a broken internet connection. Could be an area fault (calling 0800 5610061 would ID that), but more likely a failed box. The pixellated pictures would tend to suggest signal issues too.
This is primarily a user form, and VM staff are currently taking upto a week to respond on here - so you are best off calling TV Faults to report this.
150 from a VM landline, or 0345 4541111 from any other phone. Either a replacement box or an engineer visit is the required outcome.
Shirehorse
Message 4 of 5
I have exactly this problem and the same error codes, but only intermittently during watching catch-up programmes. It is quite annoying! I then have to wait about 10 minutes until the fault resets itself. Then another 10 minutes later it goes down again sometimes! Maybe I need a new box as some have said. I only have Virgin for TV and do not have my broadband or phone with them if that is relevant at all.
I am in an area that is going into Tier 3 on Saturday and people will not be supposed to come into my area from outside, which is slightly worrying from the point of view of needing to have an engineer come round, maybe a TV engineer is a valid exemption.
japitts
  • 12K
  • 1.66K
  • 2.56K
Message 5 of 5
@Shirehorse
I can only suggest you follow the advice in the previous posts!
As far as an engineer visit is concerned, if VM are able to identify yours as a box issue not necessarily requiring a visit then they should be able to replace the faulty equipment using the "Quick Start" postal method.
