FraserKay
Bigger remote for elderly?
I’m looking to see if Virgin do a larger remote. My elderly mother is struggling to see the buttons and it would be easier for her to find the channels if the buttons were larger. Do virgin make one?
cheers
Fraser
HowardML
  • 12.33K
  • 1.44K
  • 41
Superuser Emeritus
Superuser Emeritus
Re: Bigger remote for elderly?
They don't, more's the pity. There are no good big button alternatives either from third parties, that I can see. You can use one of the VM apps to control the box but I guess that will be too complicated.
