  • 31
Message 1 of 5
BT Sport No Sound
There is no sound on the BT sports channels.  I am using the old TV box.  All other channels are OK, so I don't think it is an issue with the TV.  Reset the Tivo box, reset the TV, no change.
I also have a V6 box, the BT sport channels are fine on this box.  Very odd.
The issue started last night.
Bill
  • 936
  • 72
  • 176
Well-informed
Message 2 of 5
Re: BT Sport No Sound
Quick thought did you check the cable from box to Tv is still pushed in properly ? Failing that you should call and report it 150 from VM landline choose Tv faults option.
  • 31
Message 3 of 5
Yes I did. No sound problems with any other channels.
  • 15.68K
  • 1.64K
  • 2.67K
Message 4 of 5
It the "old" box a Tivo or one of the older obsolete V+ series ones ? If it's a Tivo try changing the HDMI cable - if its a 4K tv - make sure the cable is specced for 4K
  • 31
Message 5 of 5
I fixed this. Quite bizarre. The sound on BBC 2 also stopped. So I was playing around with the settings and apps. Went into Netflix (I don't have an account}, exited the App and hey presto the sound resumed on BB2, BT Sport etc.
How odd is that.
Alan
