petersladdie
  • 133
  • 9
Audio Description
I am binge watching the series FBI that was on Sky Witness channel. Some of the episodes seem to come with AD. I do not need AD, I have never knowingly switched it on, in fact I would not know how to. How do I check the settings? Can I disable AD permanently? Sometimes I have been able to silence the AD by stopping playback and resuming from start which is a bit annoying.
Tags (3)
Scott_B
  • 300
  • 126
  • 106
Re: Audio Description
Hi.
Try this.
Press the ‘Info’ button on the top right corner of your remote control.
A sub menu comes up on the left hand side.
Press down button twice.
An option to turn off the audio description appears.
Turn it to ‘off’.
Scott.
If my answer was helpful to you please mark you post as helpful answer and consider leaving kudos.
Want to do right by your nearest and dearest and both earn a £50 credit off your bill? It's simple, Just text ‘RAF 92082 to 80011 with your postcode, account number, friend's name and phone number, so we can call them now.
