iam452
Additional V6 Box and Additional 500GB Box issues
Original set up was a V6 Box in living room and last week we added
V6 box in bedroom
500GB Box in Kids room
Everything was working great before installation and now both V6 boxes seem glitchy when connecting to each other and the 500GB box is VERY slow when connecting to Netflix & Youtube
All boxes connect through WIFI
Also now the landline is showing as line busy when we phone it and can't make calls out...
Tried for several days to call Virgin but after 1 hour waits each time we are thinking about just cancelling the whole thing... Please help
nodrogd
  • 16.47K
  • 1.92K
  • 3.94K
Re: Additional V6 Box and Additional 500GB Box issues
1) 500Gb TiVO boxes are not WiFi capable. They have their own internal modem for internet services which is known to be slow & problematic.
2) The V6 boxes need a solid WiFi connection. If WiFi is congested due to neighbours hubs it will struggle to stream effectively. The best thing to have is a wired connection, either via Ethernet or Powerline connections. Failing that if you can force the box onto 5Ghz WiFi it should perform better.
3) The landline problem is sounding like a fault & not the result of the upgrade.
There is a text assistance number 0753 305 1809. Use this & it should result in a callback. Or you can wait here for a Staff Forum Team member to respond. This may take a couple of days.
Virgin BB TV Landline. Freeview/Freesat HD, Virgin Mobile, Tesco Mobile. Cable customer since 1993
Lisa_CC
  • 3.99K
  • 236
  • 450
Moderator
Moderator
Hi iam452,
Sorry to hear you're having problems with your services. I've managed to find some details and both the TV boxes look fine. Can I ask whether they are okay when watching live channels? I've had a look at the broadband network side and everything looks okay except that your WiFi 2.4Ghz is looking a bit "iffy".
Can you look at the last post on this thread from @jbrennand and see if you can split your 2.4Ghz and 5.0Ghz networks to see if it improves?
Regarding your telephone line, can you tell us more such as whether you have a dial tone and whether you can receive calls? What happens when you try and make a call?
Lisa
