2nd incoming cable to same room
I really fancy moving my TV from one side (where the cable is) of the room to the other where there is no incoming cable. Is it possible to have a 2nd incoming cable to allow this?
Non fault engineer visit maybe required, which I'm ok with, I just don't want to call VM out unless it can be done.
  • 1.3K
  • 184
  • 618
Re: 2nd incoming cable to same room
They'll probably just opt to move the existing cable and connection. As a non fault call out, there's a standard charge of £99, but in the current climate I don't think there's much hope of getting it done soon.
  • 646
  • 120
  • 204
Hi, Is the new position for your tv in a place that you could buy cable and run internally? You can buy cable online
https://www.amazon.co.uk/Ex-Pro®-AV-Pro-Satellite-Female-Adapter-White-F-Type/dp/B01N3XZUB5/ref=sr_1...
Make sure its not shotgun type cable as this can cause problems
Rich
Send Me a PM!
Here to help! I'm a Field Technician helping out from home. Find out more
REFER A FRIEND AND SHARE £100 BETWEEN YOU
****************** ASK ME HOW ******************
