Sylacollis
2nd box ‘check cable signal’. Message
I have replaced the HDMI, checked the box and tv connections, rebooted etc. Do I assume it’s the cable in from outside. It was installed many years ago
  • 20.72K
  • 2.2K
  • 3.67K
Re: 2nd box ‘check cable signal’. Message
What "Box" are you talking about - Tivo or V6 ?
Is the 1st box OK - what box is that?
Sylacollis
I have the new trial box in both rooms. Only one is a problem. It come in via a separate connection.  I have swapped out the TVs, the HDMI cable and reset the box But it makes no difference.
Gareth_L
  • 5.67K
  • 342
  • 609
Hello Sylacollis
Sorry to hear this is happening to your additional Trial Box
I am more than happy to take a look at this for you
I will need to send you a private message to pass security
If you can check the purple envelope top right of your screen that would be great
Gareth_
