v6 box issue auto help not working
LEEEVANS69
Dialled in
We're having some issues on our end Allow us 30 minutes to get our diagnostics tools up and running again
30 minutes comes and goes
7 REPLIES 7
Hi LEEEVANS69
What is the actual issue with your V6 box?
Is there an error code showing on screen along with a message?   If so you should look it up on the following page as that may help resolve the issue
https://www.virginmedia.com/care/tv-error-code/which-error-code
Have you used the /check-services/i  function? You can also a run a test on your equipment from there.
If nothing is showing  you could also try the automated Service Status number  0800 561 0061.  This often gives details of more local issues down to postcode level.
Dave
The do's and don'ts.
LEEEVANS69
Dialled in
Thanks for the reply, done all that. Now waiting an advisor
japitts
As mentioned above, explaining what your issue is may well save you the need for a call. VM also respond on here, should their intervention be needed and this isn't urgent.
LEEEVANS69
Dialled in
Just getting a blank screen, the self help said there is an issue with the box, and to wait in chat, but that closed
japitts
Is this blank screen on live TV? OnDemand/streaming?
Are you still able to access your V6 menu system &/or EPG?
Travis_M
Hi @LEEEVANS69
Thanks for your response
Can you keep us updated with how you're getting on please? Is the V6 box still causing you issues?
Travis_M
LEEEVANS69
Dialled in
Hi yeah the box is dead, engineer is coming tomorrow.
The second one, daughters broke recently too.
