fedup991
  • 8
sound volume increases when changing to channel 5
If I use normal TV the sound volume stays about the same when I switch channels. But when using the V6 box the volume increases dramatically when I switch to channel 5. It can be very loud and is unsettling. How can this be resolved?
Tags (1)
ozsat
  • 4.32K
  • 307
  • 777
Community elder
Re: sound volume increases when changing to channel 5
Are you using an amp or the tv to listen?
If TV - have you got the audio on the V6 set to 'DD to PCM' ?
VIVID 600 (690/44mb) in Area 31
