  • 124
looking for help with remote control on V6
the remote control is loopy!! every time I press a button it moves twice.
so trying to get the password in to watch casualty before the watershed, something like 1234 becomes 11223344 obviously 1122 is not 1234.
going down the menu, is 2 pages at a time, or 2-3 lines at a time.
changed the batteries , then changed those for Duracell hi power batteries..
not worked
is it the remote, or has it lost its settings with the box?
  • 1.6K
  • 69
  • 117
Re: looking for help with remote control on V6
Hello JFord047
Sorry to hear that, I am going to send you a private message if you can reply to that I can get this sorted.
Thanks Joe_F
  • 124
Got the remote in the post yesterday... Took me a while to get it working, But I think its working now, it changes the volume and the channel up and down. so all I need really.
The Only BUT,,, I can fire in was the instructions, They are invisible to me! being Visually impaired (BLIND), I need things to be a minimum of 48 point text to see it... whatever size of text is on the instructions is invisible to me.
However that is my problem, and I would like to thank you for your help.
  • 3.83K
  • 255
  • 642
Community elder
I've had this issue several times and on different handsets - had V6 for a long time so is not a common issue.
I eventually found when it occurs I change the batteries and repair the remote.
V6 TiVo (with MRS & UHD/HDR)
VIVID 500 (500/35mb) in Area 31
SkyQ Silver Bundle (UHD + 2 minis)
