stewartkerrison
is there a problem in my area Phone -Yes Web No
I have received a new Tivo Box tried fitting it unsuccessfully
Rang Virginmedia told it was a known problem
I keep checking via 150 keeps saying still fault in my area
Went onto web page it says there are no problems
Went on online chat (typed) redirected to “correct team” once got there asked same questions I had already answered re directed to “correct team” once again
2nd “correct team” they never responded in fact the conversation is still open 6 hours later even after me periodically asking for a response.
Basically all I need to know if there is or is not a problem in my area in case Virginmedia are not aware how to answer that question is either YES or NO obviously if yes I would like to know when it will be resolved & is it causing more problems than just connecting the Tivo Box.
Andrew-G
  • 6.12K
  • 1.08K
  • 2.59K
Re: is there a problem in my area Phone -Yes Web No
The online and phone advice usually does differ - the online seems to reflect only larger scale faults, the phone notification is a little bit more precise.  Even then, many area faults are recognised and will be fixed without the phone system declaring that there's a fault.
So I'm guessing VM know there's a fault, but how quickly it'll be fixed nobody knows.  VM systems usually assign a "review date" for area faults, but they aren't reliable, particularly at the moment.
stewartkerrison
Thanks for that
all the best
Keep Safe
Stewart
