Teresa64
Just joined
extension cable for virgin tivo box
Hi new to this forum.
do virgin media provide extension cables for tivo boxes? mine is on the other side of the room to my TV so need a longer cable.   or do I have to buy one from amazon or is there another place I can get one?
cheers in advance for any help
DJ_Shadow1966
  • 7.2K
  • 1.37K
  • 2.06K
Re: extension cable for virgin tivo box
Hello
What cable are you looking for ?
If it is the coaxial the only VM can fit this and will be a non fault callout charge of £99, do not buy 3rd party coaxial cable as this can affect the signal levels not just for you but also everybody who connects to the same cabinet in the street.
Regards Mike
