Trouble is, the V6 and the newer V360 use the same box but fundamentally different software.
Can you take a picture of the popup box you're getting, and post it on here?
And the same for what you're seeing under Home > Help & Settings > Settings > Network - a picture would be great.
Allow time for the photos to be manually approved 🙂
