SteveLD
Will a TiVo V6 box connect to a PC monitor
Can I connect my V6 box to a 4K PC monitor via an HDMI lead and if so how do I set it up.
nodrogd
  • 16.18K
  • 1.87K
  • 3.82K
Re: Will a TiVo V6 box connect to a PC monitor
You can connect to monitors only if they are HDCP 2.2 compliant.
Virgin BB TV Landline. Freeview/Freesat HD, Virgin Mobile, Tesco Mobile. Cable customer since 1993
SteveLD
Thank's for that but I believe Virgin are not installing MultiRoom at the moment so I will just get a TV for now and upgrade when available.
