  • 14
Message 1 of 5
White light showing but no signal on v6 Box
Hi,twice in the last few days the v6 box is showing white but no signal coming through, have to restart box for it to work.Have checked connections & all ok. Not to much of a problem unless you are recording.Is it a known fault so should get an engineer out.Thought I would ask here first as if you call they treat you as stupid & after about 20 minutes of rechecking cables,restaring box several times you then might get somewhere.Any help appreciated...Thnx..
  • 3.88K
  • 394
  • 685
Community elder
Message 2 of 5
Re: White light showing but no signal on v6 Box
Hi have you selected the right input setting on the TV, it will be the HDMI port from the V6 to the port 1, 2, or 3 on the TV.Regards Micky
  • 14
Message 3 of 5
Hi, thnx for getting back to me.The v6 is always on HDMI (1) on my Tv,have toggled between other settings to get a signal through but always have to restart the box, cheers...
  • 16.84K
  • 1.78K
  • 3.93K
Message 4 of 5
Your symptoms suggest that your TV and V6 are not ‘handshaking’ correctly.
Two suggestions, rather than restarting your V6:
1. Rather than swapping Source between HDMIs on your TV, trying swapping to the TV (Freeview) Source on your TV then back to HDMI1.
2. Pull the HDMI cable out of TV or V6, whichever is easier, and replugging.
Click to learn more about VIP
Use Kudos to say thanks
  • 14
Message 5 of 5
Will try that next time & see if that works.Thnx..
