@MikeR371 wrote:
I went out at 5pm and it hadn't updated by then. I set it to record the programmes on the schedule from 8pm instead in the hope that this would cover it, but when I got in nothing at all had been recorded.
It won't help you now, but you set planned recordings for programmes that were then pulled from the schedule, those recordings failed by design. Given that the schedule was updated, you could have recorded the correct programme, either on your box or using TV Control app remotely.
What you can do - for future reference - is to set manual recordings. Using Home > My Shows & Recordings > Set manual recording. Those will stick regardless of what happens to the schedule.
