Paulo1Chop1
Just joined
Message 1 of 5
Virgin V6 remote - Long and Mini versions
I'm looking to get a replacement remote for my mums Tivo box.
Do the mini and longer versions of the remote essentially work in the same way?
Sorry if this is "obvious" question!
Paul
japitts
  • 10.6K
  • 1.49K
  • 2.14K
Message 2 of 5
Re: Virgin V6 remote - Long and Mini versions
There is only one version of the remote for each VM box, although you've mentioned both TiVo & V6, which also use subtly different versions - the V6 has Bluetooth whereas the TiVo is IR-only. The TiVo version is slightly bigger, which is what I'd guess you mean.
You can also order a replacement remote online at https://www.virginmedia.com/help/virgin-tv-lost-or-damaged-tv-remote/download-tv-control-app
Paulo1Chop1
Just joined
Message 3 of 5
Thanks for your quick reply, I really appreciate it. So essentially are these 2 versions "not the same"
japitts
  • 10.6K
  • 1.49K
  • 2.14K
Message 4 of 5
The TiVo (non-Bluetooth) remote on the left, the V6 on the right...
Paulo1Chop1
Just joined
Message 5 of 5
Thanks again, really appreciate your reply!
