helidoc
Just joined
Message 1 of 5
Virgin TV on a TV without cable connection
I have my main TV connected to my Virgin box in a living room, and a second box in a spare bedroom that is connected to cable (put there by previous owners) but as it is a spare bedroom, there is no TV yet connected to it.  In my office on the top floor of the house I don't yet have a a cable connection, or even a co-ax, but would like to be able to have a connected TV. Is there any way I can use my subscription on this TV without the hassle of having to have a new cable connection wired in?
Many thanks
Dave
  • 8.09K
  • 427
  • 1.15K
PrinterElf
Message 2 of 5
Re: Virgin TV on a TV without cable connection
You'll either need a long HDMI lead, or a wireless HDMI sender.
  • 3.34K
  • 336
  • 574
LittleMick73
Wise owl
Message 3 of 5
Hi do you have virgins coxial cable in the bedroom, if not you will need to pay for a second box and have it connected by a virgin engineer.Regards Micky
  • 945
  • 79
  • 132
michaeldavis
Well-informed
Message 4 of 5
The only way I can see to connect to your V6 box without the hassle of extra cabling and additional charges for a second box is to use the TVGO app.
This will allow you connect to your V6 via a computer or mobile device, whilst this does not directly mean that you can watch TV in the attic, if you install the app on for example a laptop, you could then using a TV's computer input and sound input watch TV with a minimal outlay.
You can't learn anything from a mistake until you admit that you've made it.
  • 4.89K
  • 341
  • 830
Roger_Gooner
Superstar
Message 5 of 5
TV Go runs only on mobiles or tablets.
As a TV in your office won't be the main one, Freeview (needs an aerial) might be sufficient. But if you want VM TV which is separately controlled from the main TV you'll have to pay (I think) £7.50pm for a second TV box.
Hub 3.0, TP-Link Archer C8, TP-Link TL-SG1008D 8-port gigabit switch, V6
