sgill06
  • 7
Message 1 of 13
VIVO T6 VOLUME ISSUES
When watching a programme the volume keeps going up and down. If its low and you turn the volume up it stays OK for a while then it ends up too loud so you turn it down and it ends up being too low.
japitts
  • 19.2K
  • 2.48K
  • 4.4K
Message 2 of 13
Re: VIVO T6 VOLUME ISSUES
Is the volume louder during advert breaks but quieter during programming, by any chance?
sgill06
  • 7
Message 3 of 13
No it doesn't make any difference if its an advert or a programme.
japitts
  • 19.2K
  • 2.48K
  • 4.4K
Message 4 of 13
If the volume is seemingly altering of its own accord, could the volume buttons on the remote be being inadvertently pressed?
The clue would be the white LED on the V6 flashing with an input.
sgill06
  • 7
Message 5 of 13
No we thought that too but the remote control can be on a table asaybfrom anyone when it happens
ozsat
  • 4.94K
  • 342
  • 968
Superstar
Message 6 of 13
And the tv remote itself has been checked?
1.2Gb/55Mb in Oxford (area 31) using SH5
sgill06
  • 7
Message 7 of 13
Yeah its a fairly new remote.
ozsat
  • 4.94K
  • 342
  • 968
Superstar
Message 8 of 13
A new remote is almost as likely to fault as an old one.
Have you tried removing the batteries and leaving them out of each remote unil you find the issue stops?
We had a tv that this used to happen to and it was weak batteries in the tv remote.
sgill06
  • 7
Message 9 of 13
No that's one thing we haven't tried. Will give that a go. Thanks.
sgill06
  • 7
Message 10 of 13
Well that doesn't make any difference either. It doesn't appear to be the to that the issue is with as it doesn't happen when Switch is connected.
