on 13-09-2023 11:43
Hello. Please could someone from the VM team help me? My V6 tv box has spent the last two days endlessly cycling through reboots and displays of the green screen "The DVR has detected a serious problem and is now attempting to fix it." message.
I let it run for many hours in case it did manage to fix itself but no luck. As I understand from other posts, this suggests the hard drive has failed.
I've tried to contact customer support via WhatsApp but had no response and I don't currently have the time to sit on the phone with customer support. If anyone could help I would be very grateful.
Many thanks.
Answered! Go to Answer
on 16-09-2023 15:25
Thanks for chatting with me via PM @JamShuttle 😊 Please keep me informed with how this visit goes.
Someone over the age of 18 will need to be present during the visit. Also, if you do need to change the appointment for any reason it can be done via the 'My appointments' section of your online account at least 24 hours before.
Nathan
on 14-09-2023 00:53
Hi @JamShuttle
It's your call.
If you are prepared to wait a day or two a member of the Forum Team should pick this up for you and arrange a tech visit.
Otherwise, you should call 150 from a Virgin landline or mobile, or 0345 454 1111, option 2 (Faults) It's best to call around 8am when lines are least busy
When through to the Faults option ignore all the verbal options and don't press any buttons and you should be placed into a queue and an agent should pick up the phone and book the tech for you.
on 16-09-2023 11:32
Hi there @JamShuttle 👋 Welcome to our forum and thanks for your post 😊
Sorry to see that you've had this error on your V6. It certainly does indicate that the hard drive in the box is faulty. I'll send you a PM to confirm your details to arrange an engineer to replace the box.
Just to let you know also, in doing this all recordings will be lost and can't be switched over to a new box.
Nathan
on 16-09-2023 15:25
Nathan
on 21-09-2023 22:34
Thank you for the help @Nathan_B. The visit went perfectly. V6 box was replaced and set up with no issues. The engineer even noticed that one of my ethernet cables was slightly damaged and left me a new one to replace it with.
on 24-09-2023 09:54
Thanks for coming back to us JamShuttle and we're glad to hear that your issues have now been fully resolved.
If you do have any further issues, please let us know here on the forums 👍
Kind Regards,
Steven_L
