Message 1 of 23
V6 sound quality
I’ve just installed the V6 box and, as others have advised, the sound quality is dreadful. On some channels the sound is turned up to full volume (100) and I still have difficulty hearing. Sound is from tv, no sound bar.  Any suggestions?
  • 5.59K
  • 396
  • 970
Hero
Message 2 of 23
Re: V6 sound quality
What is the make and model of your TV?
Hub 3.0, TP-Link Archer C8, TP-Link TL-SG1008D 8-port gigabit switch, V6
Message 3 of 23
Hi, it’s a LG42LA620V, probably 4years old. Thanks for your reply.
  • 5.59K
  • 396
  • 970
Hero
Message 4 of 23
On the V6, select a channel which is HD, e.g. BBC 1 HD, which is broadcast in 1080i resolution. Then try these video output settings.
1. 1080i - pass through to TV for conversion to 1080p
2. 1080p - V6 converts 1080i to 1080p
Let us know if you see any difference.
Message 5 of 23
Hi no that didn’t help, sound was worse. “
  • 3.88K
  • 395
  • 686
Community elder
Message 6 of 23
Hi leave your box on 1080p and select Keep automatic settings. Regards Micky
  • 3.12K
  • 116
  • 156
Message 7 of 23
Hi elliemay16
Thank you for taking the time to post in the Community.
I'm really sorry to hear you are having some issue with the sound since installing your V6 box.
I just wanted to pop by and see if this was still ongoing for you? Did you try the suggestion made by LittleMick73?
Let us know how it is going via your thread.
speak soon,
Louise
New around here? Find out more about the Community by checking our "Getting started guide"
Message 8 of 23
Got the same just keep going round and around and no answers.???
  • 832
  • 58
  • 266
Well-informed
Message 9 of 23
Why? This has no effect upon the V6's audio output and no TV channel broadcasts using 1080p via Virgin Media's cable TV provision. If fact, none of the video options will effect or improve the box's audio performance. The audio you get is the same regardless of the video output configurations you use.
  • 832
  • 58
  • 266
Well-informed
Message 10 of 23
Which audio output setting do you have the V6 set to? If using the Dolby Digital option then maybe try using the PCM option. The Dolby option would result in audio normalisation being applied to the audio of those channels actually encoded with Dolby Digital. THis would in turn result in an audible difference in audio levels when compared to SD channels and other channels using PCM to convey audio. You'd not lose anything by using the Dolby Digital to PCM audio output option instead of the Dolby Digital option if only using your TV's speakers to portray the audio. I'd try this to see if the levels in question improve?
