Mumofoakley
Settling in
V6 remote won’t pair with sharp tv
Do all TVs pair with v6 remote? I’ve tried all the codes and it still won’t pair
BigMrk
  • 5
Re: V6 remote won’t pair with sharp tv
I have the same problem....did you get a solution?
Spencer_A
  • 116
  • 18
  • 41
Hello,
Have you tried setting it up through the Help menu in the V6? You can try this by going into Help & Settings > Help > Program My Remote.
It'll take you through a guided setup and if it doesn't work with that still it has another option to try after which is a long winded version of inputting the codes.
Hope this helps!
Why not try our text messaging service? It's a great way to get help with your services.
Just send your query to 07533051809 and we'll text you back.
We're open 8am - 8pm Monday to Friday, 8am - 5pm weekends.
If my post has helped you at all please mark it Helpful or give a Kudos, thanks!
BigMrk
  • 5
Strangely I found this solution below on the internet after searching for hours and all other suggestions not working.....and amazingly this method worked!
The solution I found was to use the 'auto enter' method but instead of pressing the 'up channel' button I kept pressing the 'down channel'. Worked first time.
