ColinG1802
  • 24
Message 1 of 17
V6 remote pairing problem
I am unable to pair my V6 remote to my Sharp Aquos tv.
Can anyone offer a solution or is it no possible to pair at the moment
  • 6.47K
  • 1.01K
  • 1.6K
Message 2 of 17
Re: V6 remote pairing problem
Hi ColinG1802,
A member of the Forum Team posted this a few weeks ago which seems to work for most customers.
Go to HOME > Help and Settings > Help > Set up Remote.  Follow the instructions there and it should give you a series of codes to try.
You can also put 0999 in place of the code and press channel up until the TV turns off, then press OK.
You can also try the following codes for a Sharp TV. 0007 0018 0044 0094 0154 0170 0190 0308 0320 0362 0631 0675
Dave
Have I helped? Click to mark as a Helpful Answer or use Kudos to say thanks
ColinG1802
  • 24
Message 3 of 17
Unfortunately the solutions offered did not work, I entered all the codes you listed along with those on the Tivo help screens, then after entering 0999 spent an hour pressing ch up button with no success.
Do you have any other solutions?
Gareth_L
  • 6.87K
  • 422
  • 774
Message 4 of 17
Hello ColinG1802
Sorry the codes did not help much
Can you follow the same steps but this time try the 2 universal codes
0101 0460
Can you let us know how you get on
Gareth_L
ColinG1802
  • 24
Message 5 of 17
Thanks for your reply Garth, but unfortunately no luck.
I will keep trying non the less just in case the codes are updated, but any further suggestions appreciated.
Cheers
Colin
  • 6.47K
  • 1.01K
  • 1.6K
Message 6 of 17
Hi again colinG1802,
Have you tried the codes listed in the TV Remote Code List pdf  ?
EDIT sorry scrub this post, I supplied those codes earlier in the thread
Dave
Gareth_L
  • 6.87K
  • 422
  • 774
Message 7 of 17
Right after a bit of digging ColinG1802 I kind of jogged my memory that we do have an issue with Sony and pairing remotes, But I found one code that worked which was 0009
Gareth_L
ColinG1802
  • 24
Message 8 of 17
Hi Dave
Yes I found that earlier thread and have tried all those codes but none worked.
Thanks for getting in touch though, it is appreciated.
Colin
ColinG1802
  • 24
Message 9 of 17
Hi Gareth
Mine is a Sharp tv, but gave 0009 a try but not successful.
Thanks anyway
Colin
Chris_W1
  • 4.06K
  • 185
  • 255
Message 10 of 17
Hi ColinG1802, thanks for the message.
Can you confirm if any of the following work?
0011,0020,0025,0028,0033,0034,0077,0132,0154
Chris
