johnmallon1963
V6 remote losing connection
My V6 remote loses BT connection on a regular basis.
I reconnected it using the press info button method, this works but not for long.
Batteries have been replaced and remote does same.
  • 6.49K
  • 1.01K
  • 1.61K
Re: V6 remote losing connection
Hi johnmallon1963,
I wasn't aware the V6 remote could control a BT box 🤣
Have you tried to reset and re-pair the remote via the TV settings?
Unfortunately you need the TV Faults option when dialling 150 from a Virgin landline, or 0345 454 1111but best to call at 8am to avoid call queues
You could also try the text messaging service. Just send  a text with a description of new remote  to 07533 051809. Your message will go into a queue and a representative will respond to you as soon as possible. It may take a few days.
For now you could download the TV Control app and use that until you receive a replacement remote
https://www.virginmedia.com/shop/tvgo-tvcontrol
Dave
Have I helped? Click to mark as a Helpful Answer or use Kudos to say thanks
johnmallon1963
Sorry i didn't make it clear. By BT I meant Bluetooth connectivity.
Alex_RM
  • 4.5K
  • 258
  • 342
Hi johnmallon1963,
Thanks for posting and sorry for the late reply 🙂
Sounds like you're in need of a new remote, let me know if you've not been able to get this arranged and I can pop you over a private message to arrange.
Alex_Rm
