Panthergriffin
  • 7
V6 remote leaking batteries
Has anyone had an issue with leaking batteries in V6 tv remote. My story got new package and tv remote had intermittent problems from the start. Finally opened remote and found leaking battery that had corroded terminal. These batteries were supplied and fitted by Virgin installer. Asked for a new remote. New remote worked fine fkr about a month and then started same intermittent problems old one had ie not working. So I opened up new remote and low and behold the same battery on right side negative terminal spring was corroded and battery leaking. Both remotes and batteries supplied by Virgin!
Corinneangela
  • 1.11K
  • 85
  • 238
Knows their stuff
Re: V6 remote leaking batteries
Sounds like the batteries you were given may be old stock. If you have to get another new remote (or can clean the old one), I'd suggest using your own, new batteries.
