  • 23
Message 1 of 20
V6 picture and sound drop randomly
I have a LG 4K TV and a Yamaha ATMOS amp connected by a HDMI ARC cable.
If I watch Netflix or amazon prime via the inbuilt apps on my TV with my AMP I never have any sound or picture issues.
However the V6 randomly drops sound and picture or the sound goes after you have paused a recording and on live TV.  The solution so far has been replace the HDMI ARC cable and this solves the problem for a few days then it returns or shut the Tivo TV and Amp off and it starts working again.  I have purchased numerous HDMI cables from expensive to cheap and they all replicate the errors described above.
Bearing in mind that "If I watch Netflix or amazon prime via the inbuilt apps on my TV with my AMP I never have any sound or picture issues."  The error appears to be with the TIVO itself which I have had since they first came out.
What's the permanent solution please Virgin team?
Gareth
Message 2 of 20
Re: V6 picture and sound drop randomly
Having exactly the same problem here....
  • 23
Message 3 of 20
Awaiting a reply please Virgin Team?
  • 1.38K
  • 84
  • 262
Message 4 of 20
Hi Blackadder,
Thank you for your post, I'm sorry to hear that you've been experiencing TV issues.
I'd like you to try manually connecting to the network by following these steps: press Home on your remote > select Help & Settings > select Settings > select Network > select Connect to the Virgin Media Service now.
If this doesn't help at all, please could you answer the following questions:
- Do you experience this problem on all channels or just certain ones?
- Have you ensured you have the correct audio settings on your V6?
- Is this a new issue or has it happened since the box was installed?
Rachael
  • 23
Message 5 of 20
Hi Rachael
I have the correct audio settings and have followed your instructions the problem went away for one day but returned the next.  On BBC1 picture and sound disconnecting a reboot of the V6 fixed it temporarily but this isn't a long term solution.  The problem occurs on all channels.
The problem started last Autumn 2018.  I have had the box since the V6 first came out.
Message 6 of 20
I have exactly the same issue.
I have 2 V6 boxes in different rooms. The box in the lounge does not have this issue.
The box in the other room is constantly dropping the picture and sound. If I hit the TV guide, the sound returns but the picture (in the preview screen) remains off. The ONLY solution is to restart the box. This resolves the situation for a short while but it then returns.
I've tried different HDMI leads. I've tried different HDMI inputs. I've tried with different televisions. The only element that is constant is the V6. I've even had that swapped before, and the situation resolved for a few weeks before returning.
I can watch Netflix through the box without this issue (the screen flickers now and then but never cuts out).
Virgin - give me a proper solution!!!!!!!
  • 23
Message 7 of 20
Yes can I have a response from my last post please
  • 6.32K
  • 463
  • 1.09K
Hero
Message 8 of 20
What is the model of the Yamaha.
Hub 3.0, TP-Link Archer C8, TP-Link TL-SG1008D 8-port gigabit switch, V6
  • 23
Message 9 of 20
Its a
Yamaha RXV683 Music Cast 7 Channel AV Receiver
  • 6.32K
  • 463
  • 1.09K
Hero
Message 10 of 20
I wonder if there are some handshaking issues here, but all appears to be HDCP 2.2 compliant. Try a couple of options.
1. Connect the V6 directly to the LG (non-ARC HDMI port).
2. Connect the V6 to the Yamaha and the Yamaha to the LG (non-ARC HDMI port).
