AlexasSoul
  • 9
Message 1 of 8
V6 no signal after changing settings
Hey so I changed the video settings on my V6 TV box because I could see pixelation around the edges and with animations/cartoons you could see sort of a weird delay that made it look bad.
I was trying to resolve that and I guess I set the video output to 2000~ and it did show a picture when it asked me to press thumbs up. But then... it showed a purple frozen screen and then when I restarted the box it wouldn’t show any picture, as if the hdmi was disconnected.
So if there is a way to reset the video settings - how?
Once I have resolved the new issue (of no picture at all) I would appreciate help trying to resolve the original issue - which I feel like I’ve tried everything.
LittleMick73
  • 5.03K
  • 520
  • 864
Superstar
Message 2 of 8
Re: V6 no signal after changing settings
Hi what type of TV do you have a 4K or LCD as the settings are different on your V6. Regards Micky
AlexasSoul
  • 9
Message 3 of 8
Honestly I don’t remember
I just need to figure out how to reset the box or at least the video output settings
LittleMick73
  • 5.03K
  • 520
  • 864
Superstar
Message 4 of 8
Hi press home go to help and settings, settings, video, then according to what type of TV you have set if its a 4K one it will be 2160, or LCD 1080p. find out what you have by looking at your user guide. Regards Micky
AlexasSoul
  • 9
Message 5 of 8
Hey problem is I can’t see anything on the screen after I played with those settings before - when I was trying to fix pixelation
Roger_Gooner
  • 6.73K
  • 490
  • 1.19K
Legend
Message 6 of 8
You probably have a signal problem and should report this fault to VM.
Hub 3.0, TP-Link Archer C8, TP-Link TL-SG108S 8-port gigabit switch, V6
LittleMick73
  • 5.03K
  • 520
  • 864
Superstar
Message 7 of 8
Hi phone it in 150 free from a virgin phone or 0345 454 1111 from any other phone. Regards Micky
ozsat
  • 4.49K
  • 317
  • 837
Community elder
Message 8 of 8
If you set the resolution to something the tv can't handle - switch off the V6 at the mains for 10 seconds.  TV must be on at the time.
VIVID 600 (690/44mb) in Area 31
