MJennings
V6 box will not start -
V6 box loops through starting process and then shows a green screen on the TV with the message "The DVR has detected a serious problem and is now attempting to fix it........."
Unable to get through to talk to anyone about this, suspect that the box will need replacing
japitts
  • 12.16K
  • 1.7K
  • 2.62K
Re: V6 box will not start -
You're absolutely right to suspect your box will need replacing.
The quickest way is to call TV Faults - 150 from a VM landline, or 0345 4541111 otherwise. I'm not sure when they close in the evenings, but they open at 8am if you've missed the boat.
Forum staff can take a few days to work through posts on here, so I recommend you persist with calling.
