Jessicac199
Message 1 of 10
V6 box stuck on starting up
I have called up for technical support but still in the exact same position.
3 days of the same starting up page with box flashing between white and purple.
Tried all connections & even kept Ethernet cable out of box as instructed on the phone to try and connect the box to WiFi but again no further forward.
Wifi service working fine just seems to be box. Only started happening after I changed my package over the phone, although this could just be coincidence.
May need engineer/new box, please help. Thank you
japitts
  • 12.16K
  • 1.7K
  • 2.62K
Message 2 of 10
Re: V6 box stuck on starting up
[snip]
Which begs the question, what did TV Faults say/do when you spoke to them?
VM staff work their way through posts on here, but it can take a few days. So calling to report faults will nearly always be quicker...
Jessicac199
Message 3 of 10
Thanks for quick response.
They couldn’t see a connection to the box from their end so asked me to take out the Ethernet cable, a green screen came on my tv and said there was a problem detected and would take 3 hours, do not restart etc. They said when the tv came back on after the 3 hours I had to connect the box to WiFi instead. However that message has gone and the starting up message and flashing has came back on.
japitts
  • 12.16K
  • 1.7K
  • 2.62K
Message 4 of 10
Your box has died and you need a replacement.
I would hope that faults agents recognise the green screen "DVR has detected a problem" as meaning hard-drive failure, and doing anything other than replacing the box is just delaying the inevitable.
Zak_M
  • 4.44K
  • 259
  • 421
Message 5 of 10
Good morning Jessicac199
Welcome to the forums and thank you for taking the time to reach out to us.
I just want to confirm, do you have both of a V6 and a TiVo box? If so are you able to confirm the box you are having the issue with?
Kind regards,
Zak_M
Jessicac199
Message 6 of 10
Hi Zak!
I only have the V6 box, thanks 🙂
hope this helps
Zak_M
  • 4.44K
  • 259
  • 421
Message 7 of 10
Good morning.
Thank you for coming back to me @Jessicac199
As @japitts pointed out, the box dose need replacing, I have taken the opportunity to do this for you.  The box should be with you in the next 5 working days.
Kind regards,
Zak_M
Jessicac199
Message 8 of 10
Ah that’s amazing thank you so much!!
Zak_M
  • 4.44K
  • 259
  • 421
Message 9 of 10
No problem at all,
I will pop back to you on hear on Wednesday and see if you have received the box.
Kind regards,
Zak_M
Zak_M
  • 4.44K
  • 259
  • 421
Message 10 of 10
Good afternoon,
Just wanted to check in, have you managed to receive the new V6?
Kind regards,
Zak_M
