Gadge1968
V6 box stick between welcome and starting up
Trying to install v6 box and it is stick between welcome and starting up
japitts
  • 12.2K
  • 1.7K
  • 2.63K
Re: V6 box stick between welcome and starting up
2 possibilities:
1: The box hasn't been pre-activated, and needs to be...  calling in is the only way to do this. 0800 9539500 and have the box serial number handy. You may be able to do this on the automated system, otherwise queuing for an agent is the fix.
2: The box is trying to download software and doesn't have a working internet connection - the V6 needs 2 separate connections to work. Co-ax cable for your TV channels, and (ideally Ethernet) internet via your homehub for all the online stuff.
How's yours connected?
Gadge1968
Re: V6 Box Stuck on StartUp/Welcome Screen
Trying to set up the tv and it’s stick between welcome and start up, any ideas
japitts
  • 12.2K
  • 1.7K
  • 2.63K
@Gadge1968
There's no need to create duplicate posts asking the same question again, I've merged your posts to the same thread where you'll find an answer has already been provided 🙂
