on 18-05-2023 17:07
I had an old Tivo replaced with a V6 after a fault. This also coincided, kind of, with an upgrade to my package that should have included Sky Sports. I get them in SD only. I tried calling Virgin but all the options, none of which matched what I needed so I gave up. Anyone aware of what could cause this? Powered off box numerous times etc.
Answered! Go to Answer
on 18-05-2023 17:15
Based on your screenshot, you don't subscribe to Sky Sports in HD. Below is a contract with SS-HD included.
So nothing to do with your box change, and everything to do with your subscription. On a TiVo or V6, you can refresh your EPG using Home > Help & Settings > Help > TV Care > I'm missing some channels, often rendering a reboot unnecessary.
But it's unlikely to help here, your package change is the cause.
on 18-05-2023 17:15
on 18-05-2023 17:42
Thanks. If I'd known Sky Sports wasn't in HD I probably wouldn't have bothered with it at all!!
on 18-05-2023 17:45
Package changes come with 14days statutory "change of mind" right of cancellation. If you're within that period, then ask VM to revert to your previous package and then renegotiate a new one to include the £7/month HD supplement.
on 18-05-2023 17:55
The channel and package descriptions and guides are confusing. I'm also getting Sky Movie channels in HD and Sky Sports in SD which according to ChannelGuide_May_23.pdf (virginmedia.com) isn't the case. I'll guess I'll have to call to be sure.
on 18-05-2023 18:00
Sky Cinema is in HD as standard, Sky Sports is in SD as standard, and HD with a £7/month charge.
The channel guide shows 501-508 & 511-518 as premium channels. It's only SS-Mix & SS-Sports-News which are anomalies & are in HD if you have Maxit.
