V6 box making loud buzzing noise
zipster65
My v6 box has over the last few days been making loud buzzing noise. I've tried switching off fir period, reboot,  checking all cables and moved it to no avail. Its now stuck on the starting up screen and just rebooting. My other v6 is working perfectly fine. Any help/info gratefully appreciated
2 REPLIES 2
Gareth_L
Hello zipster65.
Thanks for your first post and welcome to our Community.
Sorry to hear you are having an issue with  your noisy V6 box.
From here without checking it sounds very much like the hard drive is on its way out.
I'd like to take a look into this for you and arrange for a technician to attend and swap this over
If you can check the Logo top right of your screen that would be great.
Gareth_L
Gareth_L
Hello zipster65.
Thanks for confirming the box has now been swapped out.
If you need anything else at all, Just pop back on here and we can take a look.
Enjoy the peace.
Gareth_L
