on 16-04-2023 09:45
I have a V6 box that has the 'dvr has detected a serious problem...' message. Is there anything I can do or do I need to contact VM customer support?
Thanks in advance for any suggestions.
Answered! Go to Answer
on 16-04-2023 10:16
Hi @matlock70
The, "the DVR has detected a serious problem and is trying to fix it; do not switch off for 3 hours”. message is commonly known as the green screen of death. It means that your hard drive has failed. It's not very often that the box is able to recover from this, and if by some miracle it does, then it's only a matter of time before it fails completely.
You should try speaking to faults, 150 from a VM landline/mobile or 0345 454 1111, option 2 (faults) but best to call at 8am when lines first open to avoid call queues)
Ignore all the options and don't press any buttons then you should be placed into a queue and an agent should pick up the phone and book the tech for you.
Or wait a day or two and a member of the Forum Team should pick this up for you and arrange a tech visit.
on 16-04-2023 10:16
Hi @matlock70
on 18-04-2023 10:47
Hi matlock70,
We're sorry to hear you're having an issue with your V6 box. As mentioned by newapollo, this is usually a sign that the hard drive has failed so we won't be able to fix this remotely and I would like to arrange for an engineer to come to take a look at this for you.
I just need to confirm the address to ensure we are booking the visit on the correct account. I have sent you a private message regarding this. Just click on the little plum envelope at the top right-hand side of the page to access your inbox.
on 19-04-2023 19:08
Hi @matlock70,
Thanks for coming back to me via private message to confirm your information.
I have booked you in for the next available appointment. To view this please sign in to My Virgin Media here: My VM. Once you log in scroll down to Orders & appointments then click on View your orders. Please note it can take up to 24 hours to show but you should also receive a text message with the details. You can also view this in the My VM app. If you have any issues with accessing your account or unable to see your visit, please do let us know and we’ll pop you a message to pass data protection and confirm the appointment details.
Just to confirm, there will be no charge for this visit unless:
➡ The technician diagnoses the faults as not being caused by our network/equipment
➡ The technician discovers that the fault or problem relates to your equipment
➡ The technician discovers that the fault or problem relates to any system that we are not responsible for
➡ The technician will confirm during their visit if any of these instances apply, and if so, a £25 charge will be applied to your account.
Please ensure there is someone over the age of 18 present at the time of the visit. If you need to change or cancel your appointment you can do this online or via the MyVM app by 4pm the day before the appointment. If you do miss an agreed appointment for any reason, a £25 missed appointment charge will be applied to your account on the day of the appointment.
Let us know how the appointment goes.
Take care
