johnzina
Message 1 of 5
V6 box Not Connecting to Hub.
Since I reduced my download speed from 200 to 100mbs, my V6 box (which is downstairs) is not connecting to my Hub (which is upstairs).  My old Tivo box, which is nearer the Hub works fine.  How do I  buy the VM wi fi booster (powerline adapter) - the website is no help.  Should this solve the problem, or should I return to 200mbs, which will cost another £12pcm?
japitts
  • 12K
  • 1.67K
  • 2.57K
Message 2 of 5
Re: V6 box Not Connecting to Hub.
The underlying speed of your broadband won't make a scrap of difference to the WiFi signal your router is providing.
On the V6 that isn't connecting, follow Home > Help & Settings > Settings > Network. In the top-right corner, the connection status and WiFi signal strength is reported. What does it say?
johnzina
Message 3 of 5
Sorry to sound thick, but how to I find "Home, Help, Settings, Network?  Are you referring to Settings in Windows 10?
japitts
  • 12K
  • 1.67K
  • 2.57K
Message 4 of 5
Using your V6 remote, press "Home", then scroll to "Help & Settings", press "OK", then Settings then "Network"
johnzina
Message 5 of 5
Thanks for your patience, but I’ve now learned from VM that my V6 box needs replacing.
