on 07-06-2023 02:27
Hello, my tv box wont stop beeping and is stuck in a start up loop.
Any ideas what the issue is? Ive turned off/on the mains but no luck.
on 07-06-2023 11:35
Hi @Claire1871
Sorry to see you are having problems with your V6 boix.
Try the following, it's worked for some forum members.
Turn off the V6 at switch; then on the V6 box hold down both the power button and the +button at the same time.
Then turn on the V6 again whilst keeping hold of those buttons for a further 30 seconds.
The box should reboot, the power button will turn blue, and it should reset and boot up normally.
If that doesn't work you should either contact faults or wait a few days for a member of the forum team to pick this up for you.
To contact faults call 150 from a Virgin landline or mobile, or 0345 454 1111, option 2 (Faults)
When calling Faults you will hear the automated response asking you to press 1 for the link to online support etc
Ignore all the options and don't press any buttons then you should be placed into a queue and an agent should pick up the phone and book the tech for you.
on 07-06-2023 12:48
Although "won't stop beeping" sounds like a physical fault with the hard drive which can't be repaired.
on 07-06-2023 13:17
Hi - thanks for posting this. I've just done this being guided by VM support on the chat system & it works fine. The only thing different is that the power light didn't turn blue & VM said it flashes off & on (which it did) & the welcome screen appears & release the buttons. The reboots as you say.
on 09-06-2023 13:31
Hey @Claire1871,
Welcome back to the Community Forums and thanks for the post.
Sorry to hear you have been having this issue with your TV. Has the advice provided by our VIP's helped at all with regards to this situation? If not let me know and I would be happy to assist further.
Joe
