Rachelmc
V6 Tv box - no sound
No sound. Not since day 1.
Crap installation. Phoned up no joy
japitts
  • 17.2K
  • 2.24K
  • 3.96K
Re: V6 Tv box - no sound
Is this lack of sound affecting live TV? OnDemand? Recorded programmes?
How is your V6 connected - are you using any AV kit or just HDMI to your TV? Have you tried other HDMI leads/ports? If using aany AV kit, have you checked/changed those connectors?
What tests have you tried thus far? What happened when you phoned up - were you given suggestions by an agent that didn't work, in which case what were they?
The more info you can give, the better advice/suggestions we may be able to offer by return.
