luke_r
  • 7
Message 1 of 8
V6 TV box stuck starting up
My V6 box has stopped working.
When trying to start it up it gets stuck on "starting up" and then flashes a white, followed by a purple light on repeat.
I've tried restarting it and doing a full reset but it doesn't work.
I can't seem to get a hold of anyone at virgin to report this and get an engineer to come look.
Gareth_L
  • 6.89K
  • 423
  • 778
Message 2 of 8
Re: V6 TV box stuck starting up
Hello luke_r
Sorry to hear this is happening
Do you still need this looking into
Also when you mentioned hard reset, was it this way
Turn off with the rocker switch at the back of the box
Hold the + and standby buttons together and then turn the box on and wait till you see the welcome screen.
Gareth_L
luke_r
  • 7
Message 3 of 8
Hello,
Thanks for the reply. Yes this still needs looking at please.
Yes I did the reset that way but it's still the same.
Luke
Gareth_L
  • 6.89K
  • 423
  • 778
Message 4 of 8
Thanks luke_r
I have booked the first engineer appointment we have available
You can check and reschedule this appointment through your online account if you need to
You can also cancel it if the fault has gone
Can you please let me know how the visit goes
Gareth_L
luke_r
  • 7
Message 5 of 8
Thanks a lot for arranging this Gareth. New box has been installed today with no issues.
The engineer also boosted our signal and tidied up an unnecessary signal booster we had in another room.
Much appreciated.
Lisa_CC
  • 4.11K
  • 240
  • 490
Moderator
Moderator
Message 6 of 8
Great stuff luke_r and thanks for letting us know that the engineer was able to get your V6 box working again. Please monitor it and let us know if you have anymore issues.
Lisa
luke_r
  • 7
Message 7 of 8
Hi Lisa,
My V6 box is perfectly fine now.
However, while the engineer was here he checked my internet connection and "boosted the signal" too. In the process he removed a powered signal booster we had plugged in in another room as he said we didn't need it.
Since then download speeds have dropped dramatically and we've had the internet completely drop out three times in the last two days, but this never happened before.
Previously we were getting at least 60mbps but it has dropped to 5mbps!
Luke
Gareth_L
  • 6.89K
  • 423
  • 778
Message 8 of 8
Hello luke_r
Sorry you have had to chase this up again
I thought we had cracked it but sadly not
I have had to arrange another engineer again so to  make sure this gets fixed
The visit will be with a senior engineer
You can again check the time via your online account
Gareth_L
