I seem to be fighting an ongoing battle with my V6 box and loosing.
1)Random unresponsive remote, can take 30s plus to turn on the box with multiple presses. Channel surfing the same, typing the channel number is often impossible as it times out. Yet last night it was fine with no intervention.
2)On changing channels it can loose sound, resolved by changing channel, often several times and returning to the desired channel.
3)When watching a program it sometimes decides to record that very same program, when this happens it rewinds me by 5 minutes which is rather irritating.
I have tried:
1)Clearing the cache with the remote sequence - I initially thought this fixed my issue and have done it several times however of late I'm really not sure as the problems can be back in a day or 2.
2)Swapping the HDMI connection on the back of the TV, I also thought this worked with the sound issue, but unfortunately that was just a coincidence.
I'm convinced my box has a fault, I used friends and they exhibit no such problems at all!
I've phoned the technical helpline, I can't suss out how to speak with anyone and just end up running the automated test.
What now?
New V6 box ideally in my opinion!
