Rob198567
V6 Remote pairing problem
Hi, I've received a New remote for my V6 box. I've followed all the steps with the pairing and can get the remote to bleep and pair, however this connection only lasts for around 20 seconds and stops working.... I've changed the batteries and reset the box but the same thing keeps happening.
Please advise
  • 6.55K
  • 1.02K
  • 1.63K
Re: V6 Remote pairing problem
Hi Rob198567,
Have you tried resetting the remote back to factory defaults first?
Press TV and Clear at the same time until the remote light flashes green.  Then press thumbs down 3 times followed by OK twice.
This should reset the remote and force it to re-pair.
Dave
Have I helped? Click to mark as a Helpful Answer or use Kudos to say thanks
Rob198567
Hi, thanks for your reply. Yes I have. 3 times infact. I'm completely out of ideas.
