bantha29
Message 1 of 5
V6 Remote Pairing Problem
Recently took delivery of new remote for our V6 box as old one kept falling apart. Trying to pair the new one but with no luck. Have unpaired existing remote and followed usual procedure of pressing info for 7 seconds but light stays red instead of going green.
Any suggestions?
Tags (3)
  • 5.75K
  • 916
  • 1.36K
Hero
Message 2 of 5
Re: V6 Remote Pairing Problem
Hi bantha29,
It's possible that your replacement remote is not actually a new remote and needs unpairing.
To clear your changes and reset your Virgin TV remote to its original settings:
  1. Press and hold down Clear and TV on the remote at the same time until the light on the top of the remote flashes green twice
  2. Press Thumbs Down three times, then press OK
  3. The LED will flash green twice and exit programming mode
Help on pairing the remote is here using-tv-remote
Dave
bantha29
Message 3 of 5
Many thanks. This worked a treat! 👍
  • 5.75K
  • 916
  • 1.36K
Hero
Message 4 of 5
HI bantha29,
Thanks for the update, I'm pleased it worked.
Hopefully you won't have any further problems, but if you do, just pop back onto the forums
Dave
PhilSand
  • 6
Message 5 of 5
Hi, I have the same problem, but my remote just simply will not flash green after holding the Info button down for 7 seconds (or for 30 seconds either). Could it be that I have been given a remote that will not pair? I have two V6 boxes and both remotes are the same and have the same problem. I have noticed that some remotes are different - mine has a Subtitles button, but some do not. Any ideas please? Thank you
