Maincat
  • 41
V6 Remote Control Volume Switch Not Working
Hello,
The volume control on the V6 remote doesn't work.  All other controls do work on the remote.
Has anyone seen this before and can offer some advice please?  Thanks.
Ernie_C
  • 18.4K
  • 2.01K
  • 4.5K
Re: V6 Remote Control Volume Switch Not Working
The V6 has no volume control, that is down to your TV.
You can find out how to do that here:
https://www.virginmedia.com/help/virgin-tv-using-tv-remote
