ian19461
V6 Problem
My V6 box keeps stopping the signal to my Samsung TV. Picture/sound disappear and message pops up to say loss of signal. Many times this has happened and I have had to perform the setup in order to get the signal back (very frustrating). Now when this happens the message seems to think that the problem lies with my "SKY" setup, I don't have sky!!
Has this problem happened to anyone else?
japitts
  • 12.17K
  • 1.7K
  • 2.62K
Re: V6 Problem
What makes you think it's the V6 output not working, as much as the TV input not working?
If you're getting a message referring to "Sky", that wouldn't be generated by your V6 box but could easily be your TV having a particular HDMI input labelled as cable/satellite.
Have you tried another HDMI lead in this same slot, or indeed another HDMI slot? What's the exact model of your TV?
ian19461
Re: V6 Problem
Satisfied that TV not the problem as it has only started since V6 box replaced due to a fault. I have another box upstairs and if I interchange them the TV / V6 box works fine.
