  • 8.09K
  • 427
  • 1.15K
PrinterElf
Message 11 of 22
Re: V6 Ethernet connection using a powered netgear hub
@Ashg wrote:
So from you've answer that would mean I would have to run 20 plus meters of coaxial cable from the back to the front of my house.
Correct, yes - all VM boxes need a coax connection, and the V6 needs either a wired or wireless internet connection as well.
@Ashg wrote:
From what I understand you cannot do that because of the signal drop.
Emphasis added. You, the end user cannot do it. However VM will be able to because they can play with the power input to your property, apply and attenuators as appropriate to ensure that both units have the correct power levels.
@Ashg wrote:
Plus I would have to do that internally which is not possible.
The VM tech would route it outside for you as needed.
  • 164
  • 15
Ashg
Up to speed
Message 12 of 22
I know all of the above thank you  As I said before none of that was my original question Man LOL
Other members have taken this off topic with info I don't require and never did in the first place!
  • 26.72K
  • 1.15K
  • 4.47K
Message 13 of 22
then the answer to your original question....
No
Click to learn more about VIP
Use Kudos to say thanks
  • 164
  • 15
Ashg
Up to speed
Message 14 of 22
Thanks but I have the correct info from elsewhere.
  • 26.72K
  • 1.15K
  • 4.47K
Message 15 of 22
that is the correct answer, you need a coax connection for all boxes and as the terms you signed up to you can't modify the network (cable)
  • 164
  • 15
Ashg
Up to speed
Message 16 of 22
I didn't ask any of that .
  • 164
  • 15
Ashg
Up to speed
Message 17 of 22
Could a moderator please close this thread. Thank you.!
  • 26.72K
  • 1.15K
  • 4.47K
Message 18 of 22
threads don't get closed that is not how the forums work
  • 8.09K
  • 427
  • 1.15K
PrinterElf
Message 19 of 22
As long as you're connecting the box to coax, and an internet connection fast enough to support any streaming you may wish to do, it doesn't matter how that connection is routed between the box and the Superhub.
  • 164
  • 15
Ashg
Up to speed
Message 20 of 22
