callumbrucie
V6 Box Help Section
Hello,
I’ve just got the V6 Box and I’ve been trying to access the help section from the Home Screen but when I select help in the settings it says “one moment” but then does nothing and goes back to the Home Screen. I have tried resetting the box but nothing is working and I want to set up my virgin remote with my TV but can’t access that help section.
japitts
  • 8.61K
  • 1.21K
  • 1.67K
Re: V6 Box Help Section
Can you use any of the other apps/streaming services?
How about OnDemand services?
You've not said how recently "just got" is (and was this a fault replacement, or new install?), but a restart often helps these things. Home > Help & Settings > Clear or restart my box
callumbrucie
Yes got all the other services.
Got the box this week, as I upgraded my services! Everything is working apart from the help section part and I have tried restarting the box.
