Rockfish70
  • 22
Message 1 of 7
V6 Box Constantly Looses WiFi Connection
Having daily issues with my V6 box, it is constantly loosing its WiFi connection. Every day at least once a day it looses the connection when I go to network diagnostics it says no signal, even though the Xbox and Apple TV both still work, they are all on the same tv stand so I know the WiFi signal is fine.
a full restart of the box fixes it every time, only thing I have noticed is V6 box seems to get much hotter than it used to.
is the WiFi in the box on the way out?
japitts
  • 20.72K
  • 2.65K
  • 4.75K
Message 2 of 7
Re: V6 Box Constantly Looses WiFi Connection
Can you clarify which network diagnostics screen you're checking, to get this conclusion? There's a few "system info" screens on TiVo software that aren't always reliable in the info they give.
The one you want to be checking in this scenario is under Home > Help & Settings > Settings > Network. When you have this problem, what shows in the top-right? And are there any options to reconnect?
Tom_W1
  • 3.66K
  • 198
  • 342
Message 3 of 7
Hi @Rockfish70 thanks for your post although I'm sorry to hear of your concerns raised.
Okay so you've already clarified it only seems to be impacting the one device, that's helpful - is it possible to try and connect the V6 box via an ethernet cable as this is generally anyway, more stable than wifi or is your Hub in a different area of the house?
In addition, does the light on the V6 light up that signifies a lack of connection and that's how you realise the wifi has disconnected from it?
Many thanks
Tom_W
Rockfish70
  • 22
Message 4 of 7
There’s a light on the box that comes on when it looses internet.
Changed connection to 2.4ghz and seems stable at the moment. Only lost connection once but that was due to broadband issue in the area according to virgin service checker
ethernet not possible due to location of box
Travis_M
  • 4.64K
  • 170
  • 340
Message 5 of 7
Hi @Rockfish70
Thank you for your reply
How has your connection been since your last post, have you noticed any improvement since changing to 2.4ghz? Please do provide us with an update.
Travis_M
Rockfish70
  • 22
Message 6 of 7
Sorry it’s been awhile 2.4 is working fine
John_GS
  • 15.74K
  • 798
  • 1.46K
Message 7 of 7
Thanks for the update Rockfish70
Glad to hear things have been sorted 🙂 if you do ever need anything, please pop back and we'll be more than happy to help.
Best,
John_GS
