Hello,
Our Tivo box won't switch on like normal, it has an amber light on the box which turns white and then back to amber when I have attempted to reboot the box. The box is stuck on the multilingual welcome screen, and as well as this is making a beeping noise followed by a whirring sound.
I have turned the box off and on multiple times, as well as holding down the power button for 5 seconds for it to reboot, this above issue always being the outcome of these tries.
Does anyone know what I can do to fix this?
Thanks 🙂
