Tivo box Red/White lights cycling
Makakar
Hi All,
Tivo box is currently cyling red/white lights, it's not power cycling as it stays stuck on starting up, any ideas?
2 REPLIES 2
japitts
If your TV box isn't powering up, it sounds faulty. The quickest way to report this is to call in...
150 (from a VM phone) or 0345 4541111 (from any other phone).
VM staff respond on here, but it may take a few days.
Tom_F
Hi Makakar, thanks for getting in touch.
Apologies for any issues with your TV box. I wasn't able to check on this using your forum details alone on this occasion, so in case you still need help I will get in touch via PM. Just look out for the purple envelope and we'll take it from there.
Tom
