Tivo V6 remote. Stop sound when tap buttons
MRM3
How do I stop the sound on my new V6 remote when i press a button please?
1 ACCEPTED SOLUTION
Accepted Solutions
Graham_A
Home > help & settings>settings>sound effects volume>off
________________________________
Graham
I'm a Very Insightful Person, I'm here to share knowledge, I don't work for Virgin Media, I'm a VM customer. There are no guarantees that my advice will work. Please read the FAQs
4 REPLIES 4
MRM3
Anybody?
Prss the mute button which has a picture of a speaker with a line through it.
As it is a while since I had a V6 box, I am not sure whereabouts it is on the Remote.
Tavis75
Knows their stuff
There is an option in the settings menu of the V6 box to do this, can't remember where exactly (and can't check my V6 right now, but it's in there somewhere!)
Graham_A
Graham
