AJB1607
Tivi box flashing red power light
My TiVo box has frozen, I’ve turned the power off as per the help guides and restarted the box. After a number of tries and disconnecting the cables I eventually got it to start up. However, the lights on the box are flashing and the standby button alternates between white and red.
The screen is stuck looping on Starting up... and then shutting off.
Any suggestions to get it going again? Will phone CS tomorrow
japitts
  • 10.46K
  • 1.46K
  • 2.11K
Re: Tivi box flashing red power light
Do you have a TiVo or a V6? You've mentioned both, if you're not sure you can check here
It won't make much difference to the end result - a box that won't boot has a fault and your suggestion of calling VM faults in the morning is the best way to go.
